HELP ...valve cover gasket kit help!!
i have a 94 accord and i noticed some oil around three of the spark plugs,
after searching this forum ,i thought that this is probably the valve cover gasket and spark plug gaskets that need to be changed .... (doesnt sound too hard for me ) So i went ahead and bought the kit and took off the valve cover ...
now i can see where almost all the new components in my kit go
1 - the valve cover gasket -obvious
2 - the 4 spark plug tube seals ( the thicker ones go around the hole where the spark plug wire tube goes into .
3 - the 4 valve cover gromets - ok , these are also obious as i had to take the old ones out to take off the valve cover.
***4 - here where I AM STUCK - the 4 spark plug seals ( O rings) - I DONT KNOW WHERE THESE GO AS I CANNOT FIND OLD ONES ON THE CAR
PLEASE ANYONE ANSWER ASAP as the car is opened up
thanks for the replies !!
