Help, hatch leaking
Professor
I just attacked this problem on my '91 Si Saturday. I sprayed water all over the hatch with a garden sprayer and no leaks. Then I pulled out the headliner to check the drain tubes. Both of the rear tubes were full of water, indicating that they were plugged up. I disconnected each of the four tubes and blew them out with compressed air. I also blew up through the drains to send any crud stuck in there flying into the wind. Hopefully this will fix my leak. I guess I'll see when it rains.
check under the two strips on the roof (one on each side, where the roof meets the pillar above the door). most likely the silicone or whatever it is in the seam is cracked like mine, letting water in. just be careful if you pull the strips out because they have metal in them and bend easily and are 40 bucks a piece from honda.
rebuilding
Also check where the hatch meets the body. The hinges over time shift and move allowing water to get under them. You'll be able to see bubbles and probably some rust too. I had a leak in my rex for about two years, I changed the drain tubes the hatch seals and after I removed my hatch did the body work around the hinges and my problem was solved.
I know this is an old thread, but my hatch is still leaking on my 91 crx. It's raining now and it's dripping like crazy. It's dripping out of the plastic molding piece where the shock that holds the hatch up meets the body. I've sealed up the washer nozzle, and it still drips. I've put the water hose in my sunroof, and the drain tubes work. How hard is it to remove the headliner? This is going to be the only way for me to see where it's coming in. Has anybody ever done this without messing up the headliner?
Boo Boo Kitty F*#k
Did you do this mine was also leaking from cracks in the body seam filler. it leaks in runs down the piller and out the hole right above the hatch strut. Just pull the rain gutter piecses off and seal under them.
I keep reading this ongoing horror story and wonder why it is. Here is another view.
Our '89 Crx Si has a DX roof skin professionally installed as part of the race car setup. The gutter seals (long black strips) were replaced and the seams were properly welded and caulked. The squirter was replaced and sealed. The hatch seal was replaced. Why do I have leak-because the hatch galss has trim on it and the seal has deteriorated over 15 years. Remember that this car was dismantled except for the quarter windows themselves-new outer seals and caulking were done after paint. Thus there are only2 places thewater can come in-the hatch trim or the taillights. Yes I get a puddle in the spare tire well and some drops on thewheel arches-but that is the extent of it. Will test my theory unless someone else is willing to. This is the only reasonable explanation for those who are finding water on the hatch end of the struts IMO.
I think you and jc836 are correct. I took it off again, and saw a hairline crack in the seam filler at the end underneath the strip. I put some glue on it and put the gutter stip back on. I sprayed some water on it after the glue dried the next day, and it did not leak. I'll know for sure the next time it rains. Thanks for the info.
