Crank angle sensor
Crank angle sensor
Havng problems with 91 Civic, 1.5, dual port injection....need to check crank angle sensor, but don't know what the readings should be for ohm meter...Haynes manual shows different coloured wires than what my Honda actually has, so I'm hoping someone can advise. 5 wires....don't want to replace distributor is this is not the problem.... Thanks
The Code
Code indicated injection..but pulled fuse to reset and am not able to determine any other codes as I have to start the car to do so...and car won't start. According to Haynes manual,the crank sensor can affect the injection...hence, giving me that as the error...so no further ahead...any ideas
