92 LS in 89 CRX
WHAT OK YEAH!
92 LS in 89 CRX
I just got a 89 Crx For $100 but the eninge is no good. I have a 92 LS engine will this eninge work on the 89 CRX? Is it a direct bolt on???
Any help would be good
yes it will fit.search out your problems first if u dont get a response come back.
al u need is motor mounts and wiring.and a few other thing like axles/ecu/tranny/.but search first.
the b18b from an ls engine requires mounts and an adjustable shift linkage...it also depends on what type of crx you have b/c you have to convert to MPFI if you have a dx, or convert to dx/si front knuckles if you have an HF to fit the larger axles
