Ecu? where can i get a ecu for cheap new or used?
Old 07-31-2004 | 05:32 PM
civicdistress's Avatar
civicdistress
Default Ecu? where can i get a ecu for cheap new or used?
I have a 91` civic hb. I am currently doing a d16z6 swap. I need an ecu to activate the vtec. I hear the p27 or p28 ecu will do the job, but how do i get my hands on one?
Old 07-31-2004 | 06:48 PM
91_CiViC_RiDeR's Avatar
91_CiViC_RiDeR
Passing_U_N_A_CIVIC
Have you Tried E-bay????? Or try this site here and see if you can find something http://www.eautoworks.com/html/ape-a...ulley~Kits.htm GOOD LUCK!!!
Old 08-29-2004 | 12:01 PM
preludedriver99's Avatar
preludedriver99
I've got a pr3 5 speed obd0 ecu that all you have to do is run 3 wires to wire up vtec. It's chipped from nippon motorsports to run a jdm b16a!
Old 08-30-2004 | 04:33 AM
89crxinprogress's Avatar
89crxinprogress
you don't have to have a computer to activate your vtec. all you have to do is cut the plug then run a wire to a switch on your interior. then you have control of when your vtec kicks in. if you want it to kick in a 3500 then all you do is flip the switch.
Old 08-31-2004 | 01:31 AM
Kai's Avatar
Kai
Rotorphile.
Don't bring up dead threads to sell your shit.
That's one of the stupidest things I've heard in a while. Use an RPM activated switch, readily availible from summit racing, for around $45. That will activate VTEC at the exact RPM you want it to kick in without needing to flip a swtch every time. I recommend sticking with the stock engagement point until you get an aftermarket cam or have yours reground, however.
Old 08-31-2004 | 12:24 PM
89crxinprogress
but say your car is an everyday driver and you don't want it to kick in every single time you hit 3500 rpm for gas milage purposes. ( i know vtec probalby doesn't use that much more gas and if you are building a race car then you aren't that worried about it but every little bit helps with the way gas prices are these days.)maybe that is stupid too, i don't know.
Old 08-31-2004 | 01:45 PM
Kai's Avatar
Kai
Rotorphile.
That's still pointless. If you don't want it to activate, just put an on/off switch in the RPM signal line of the RPM switch. At least that would make a little bit of sense.
The easier solution would be to shift earlier... like you're supposed to under normal conditions.
