D16A6 / D16Y8 mini me article
NinJA
Hey guys-
Well, first all I wanted to do was change the clutch. That turned into, "Why not just pull the motor?" I kind of got side tracked into this and some suspension work.
It's not quite done yet. It needs editing and finishing up. I tried to write it so that anyone can do it, I hope.
Any feedback?
http://www.geocities.com/senpai_performance
Any feedback?
all in all i think this is well done
some notes:
honda made the d15b a 150hp sohc engine with a vtec head and a 3 stage intake manifold that would be more akin to the sohc vtec "type r" than the d16y8...where the d16y8 head on the d16a6 is a regular "mini me" swap
the intake manifold works in tandem with VTEC but is not part of the the actual system...only the operation in the head suffices here
some notes:
oops...my bad...didn't realize i typed in 150hp (it should be 130hp)
the d15b was a great engine making similar power the zc made but with sohc design and .1 less liter...reason being was that the d15b had a 3 stage vtec system that was staggered with its intake manifold (12 valve operation mode under lean with a more turbulent air delivery to maximize torque - a green light would actually show up on the dash, 2nd stage was from 3000-6000 rpm with 16 valve operation with less turbulence in air delivery, at 6000+ the 2nd lobe [3rd stage] kicks in and the air delivery is a straight shoot with no turbulence)
