87 CRX LS swap
Old 06-26-2004, 10:16 PM
Keebler
You Dream It, We Live It.
Keebler's Avatar
Default 87 CRX LS swap
i'm about to buy a 87 CRX Si and i was wonderin if an LS Integgy motor will fit in it, if it won't, what would be a better swap?? :thinking: :eh:
Old 06-27-2004, 04:35 AM
1stGenCRXer
GWAKS- Tech Geekifier
1stGenCRXer's Avatar
Fit yes, but any b-series is going to require mounts, wiring work, axles, custom shift linkage...
-Harry
AIM: NDcissive
Old 06-28-2004, 09:17 AM
Keebler
Keebler's Avatar
custom shift linkage? i thought i'd be able to use what comes on a stock 89 rex? or would that not work either? what all would i need to do?
Old 06-28-2004, 09:47 AM
1stGenCRXer
You'll just need to cut the stock linkage and weld in a piece of metal to make it the right length, both the steady rod and the shifter.
-Harry
AIM: NDcissive
Old 06-28-2004, 10:14 AM
zoomin
zoomin's Avatar
ok my friend got a crx (we already took the stock blown engine out) and he got a 1990 b18, 5spd tranny, harness and ECU out of an LS teg. now i got 3 questions since i'm helpin him do the swap.
1. what do i do with the wiring...would anyone have any diagrams? will i need to seperate the lighting harness from the engine harness? do i need to repin anything?
2. could someone give me the dimension of that piece that has to be welded in? i have a good friends who welds for a living and he can do almost anything. does anyone have any pics of the welded linkages for the b18 swaps?
3. is there any way to get around the fact that i need to buy expensive engine mounts? are there any JY parts that i could use? or modify the stock ones?
thanks alot...we hope to get this running soon so we can turbo it
victor
Old 06-28-2004, 10:28 AM
A_PHOBIA
A_PHOBIA's Avatar
there is no way around the mounts.try place racing motor mounts there half the price of the hasport ones and work just as well,you can use the passenger side mount from an integra and the rest are from place racing there like $250. as aposed to hasports hefty price tag.
Old 06-28-2004, 02:06 PM
Keebler
Keebler's Avatar
thanks. that helped out a lot.... i'll post pics along the way to show you whas up.... can we say sleeper??
Old 06-28-2004, 09:31 PM
zoomin
zoomin's Avatar
how about the wiring? any advice on that? thats where i'm most lost.
thanks
victor
Old 06-29-2004, 05:39 AM
1stGenCRXer
thanks
victor
The wiring for the LS is pretty straight forward. Guys over on www.redpepperracing.com will be able to help you with it more than I could.
-Harry
AIM: NDcissive
Old 06-29-2004, 06:28 AM
bluetwo
Relevance is irrelevant
bluetwo's Avatar
good luck with this crx. It should be awesome, so remember to post those pics whenevery yu get em. Hows the exterior?..........
