CRX VS S13 240sx.
were do you live? all the smog laws change state to state.
i will tell you what you need is a crx/hb there f*cking great.
if you lice in ca,none of the b16 will pass emisions with out modifications and approval from the inspection ref.a usdm b18c"gsr"will pass smog if you convert your car to the same obd as it would have come stock from the factory.auctually what you want is a usdm b16 "outs the 99-00 si's and a few del soles these would work for emissions too.
Just Hazin'
when ordering online or through someone, how woud i know if it's a USDM. I mean, just because the B16A2 came in the late model Sols doesnt mean that that any B16a2 is going to be a USDM motor....so confusing......
How does one wire and OBDII system into a OBD0( 2000 LS b18 into 89 CRX) I mostly work on Subarus, im new to honda trying to learn as much as I can. Does anyone have links or can explain the swap?
I'm Shy :(
Originally Posted by bluetwo
I think i'd rather have a fast CRX than a 5.0 anyday. I've driven both and that's my opinion, but the 240 could be a great car. Good luck deciding that one... for traffic and tight spots the smaller car has obvious advantages.
Oh and cuz you're moving to L.A they'll jack any car they want to it doesn't matter wtf it is. If someone wants it they'll get a hold of it.
Rotorphile.
If we want to pick beans between a fast 5.0 or CRX, I'd take the CRX simply because I know how to work on one.
Oh, and I hate Fords.
Except for the Torino.
Mopar > Chevy > doggy poo poo > Ford :chuckles:
Originally Posted by HAZE
so....that brings the question to what type of B16...? I want to pass smog. Also, how much will the engine run? I have a friend that can handle the labor.
Also, I'm not exactly sure if they check to see if the ecu is usdm. So you may be able to pass with a jdm p30 ecu.
The smog referee will smog the engine as a del sol vtec engine (b16a3).
