say hello to my new little friend! :) (DUW)
Old 06-16-2004, 05:20 AM
Bmpn
Audiophile
Bmpn's Avatar
Default say hello to my new little friend! :) (DUW)
I copied and pasted this from another forum, I know I put something up a week or two ago and this may be a bit redundant, but get over it
this weekend I am finally picking up an 87 CRX Si
I've got the audio part covered, but something about 91hp just doesnt seem to go over too well in my head. What are some cheap/free things I can do to it (very inexperienced!)
Here are some pix...
I saw some Motegi 15's I would love to throw on it, but as you can see, there is a bit of touch up work on the paint/body that needs to be covered first before too much aesthetic stuff can be done!
Old 06-16-2004, 08:15 AM
B20powered
You can't see me
B20powered's Avatar
Pretty descent, get a new engine..
Old 06-16-2004, 09:00 AM
Pete
Civilian
Pete's Avatar
an engine swap isn't really cheap, but it's really the only upgrade that would have a significant influence on the car's power (unless you boost it, but why when it costs more than a b16?).
Old 06-16-2004, 12:50 PM
Bmpn
Audiophile
Bmpn's Avatar
yeah the engine has 177k I think on it.
others suggested a new exhaust, intake, etc, probably the normal stuff
Bmpn
Audiophile
Bmpn's Avatar
ps what does a b16 run for price?
Im just curious now
Old 06-16-2004, 01:27 PM
ED9man
driver
ED9man's Avatar
is it a D-series?
fuel injected?
Old 06-17-2004, 02:21 AM
Pete
Civilian
Pete's Avatar
it's a B Series, hence the name "B"16, and it is MPFI (Multi Point Fuel Injection). A complete swap can run you between $1,000-1,400 (at least those are the ranges I've seen). Not to hard to install if you know what you're doing and you have all the right tools. It'll prolly run you about $400-600 for labor at a mechanic to install it for you.
The first post in this forum has links that tell you all about the different kinds of swaps that you can do and what to expect. Hope that helps.
Old 06-17-2004, 11:41 AM
Kai
Rotorphile.
Kai's Avatar
Originally Posted by Bmpn
[i]
Are you sure that's an Si? Is it fuel injected? It doesn't look like an 86-87 style Si to me.
First, those things (D15A3's) are pretty mod happy. With ITB's those things get quick fast, same with other engine work. Secondly, you can turbo that car for way less then you could get a B in.
Plus about another $1500-$2000 for the mount parts to get it in to the older body.
Old 06-17-2004, 12:05 PM
A_PHOBIA
A_PHOBIA's Avatar
thats not an si.your going from a carbed motor to fuel injection and its not going to be cheap.the si came with a rubber wing that fit flush against the hatch,so you need to change from the carb setup to the fuel injection,there is other little differences in the body from the si than the other models.
Old 06-17-2004, 01:33 PM
rydnby 4
rydnby 4's Avatar
wow, another "Mainah"...didnt know there were any others on this board
looks like the bangor area too...darlings?
Quick Reply: say hello to my new little friend! :) (DUW)
