clutch?
GWAKS- Tech Geekifier
Stock? about $160
Aftermarket $160-1200+
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
I'm Shy :(
Ok instead of starting a new thread, I thought I would just continue from this one.
Anyways will a 90-91 Crx Si Clutch and clutch plate work on a 89 crx si? Here are the specs from a 90-91 crx si clutch: Single Plate Clutch Set. 20 spline; 22mm hub ID; 212mm disc.
This is all oem of course. Thanks in advance.
I believe it was the '88 that had a different spline count... Someone else will know for sure.
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
I'm Shy :(
I got the numbers from a guy on Honda-Tech.com Here they are and it will work accoridng to him, I'll be buying a new clutch tomorrow:
88, 89, 90+ are all different.
88 needs 88.
89 can use 90+
Talkin if flywheel/tranny the same year.
Spline = tranny input shaft
88 19 spline, 200mm clutch disc
89 20 spline, 200mm clutch disc
90+ 20 spline, 212mm clutch disc
now.. some numbers im almost 100% sure are not accurate but u can get the idea of which clutch works on what tranny/flywheel combo.
a 90 clutch will fit the 89 tranny but it will overlap the flywheel, but still works just fine.
88 needs 88.
89 can use 90+
AwwsChwA
Engine Swaps, Tech & Tuning
3
04-15-2003 11:17 AM
