headlights?
headlights?
What headlights will fit on my 88 CRX Si?
Will only the 88-89 CRX headlights fit or will the 90-91 fit too?
Are any other 4th gen headlights compatible?
because I have one burned out and an brand new OEM is expensive.
I'm RICK JAMES, bitch!
I think all 88-91 headlights were the same. I believe it was the actual fender that made how the corner lights attach different. But I could be wrong. You most likely could just switch out the headlight bracket if your headlight was broken and that would probably work so the corner light bolted up right.
flipped cracka
Do It Yourself
20
03-07-2007 06:20 PM
SammyD
06-07-2003 03:37 PM
