So I tried Starting my 89 Crx Si today...
I'm Shy :(
And the fawker won't start. It has a stock d16a6 in it. I tried putting gas in it because it has been sitting for awhile and the tank was empty so I put some gas in it. Well that didn't do crap for the car. I then tried getting a new battery and tried that. That didn't do anything either. I don't know what too do next. Should I change the ecu and possibly the distributor? Change the wires? It'll crank and crank and crank over but nothing happens. It sounds like it'll want to start over but it won't. If you guys have any suggestions on what I should do next let me know. Please post up or pm me. I'd appreciate the advice.
I'm Shy :(
Originally Posted by brtecson
check if youre getting any spark
First off, did you try starting the motor before you bought the car? Second, don't bother fixing the problem and just go buy yourself another Si motor with lower miles or upgrade to a bigger motor. IM me when you're online and talk to me, maybe I can help you out with your problem.
Jeff
Jeff
you dont need to get another motor unless you want to or need to. First off 3 things make a car start, compression, spark, and fuel. Check them each and make sure there are all there. First Spark..I dont know if this is a ghetto backyard mechanic way but its how I do it... take one of the spark plug hoses out of the head, take a screwdriver (with plastic handle) and stick it insdie the spark plug hose (make sure it touches the metal ring inside) and then hold the hose over something metal ( a bolt will do just fine) and have someone try and start the car..if it sparks you got spark. ( I hoped I explained it good..if you have any questions email me). Second if there is no spark check fuel...on the firewall you will have a fuel filter...loosen the bolt the fuel comes out of (not too much !) and have someone turn the key as if they were going to start the car..if you got fuel it will leak a lil out or spray a lil (depending on how loose you lossened it). Thrid is compression...the easiest way to check this is go to sear or pep boys or auto zone and buy one and just follow the directions. Hope this helps good luck
pukimonster
yea, you dont have to buy a different engine. replacing a distributor or fuel pump or something small like that will be way easier than an engine swap, even if it takes a few tries to diagnose your problem. so basically, do what redlinerz said.
pukimonster
the car in my avatar ran fine up to 306k miles. It was then sold, and a zc was put in there. i wouldnt be suprised if calidude could get a few more years out of that drivetrain.
