damnit i killed the rex now it wont start
Old 02-23-2004, 02:28 PM
90_crx_flaze
Drift King
90_crx_flaze's Avatar
Default damnit i killed the rex now it wont start
Yesterday i was showing my cuzin the that my passenger side half shaft needed replaced so i backed up and cut the engine and left the key partially on now it wont start. the key was on all day from like 12-6 and when i got in to go to wally world it cranked and turned over and i tried again now it wont turn over and it keeps just tryna turn over and it wont turn over
Old 02-23-2004, 06:43 PM
90_crx_flaze
Drift King
well i know the distributer cap is good cuz that didnt solve the problem the battery charger didnt work so its not the altanator
Old 02-24-2004, 12:37 PM
Vividkid82
Vividkid82's Avatar
try and jump the car....
Old 02-24-2004, 01:00 PM
S2Kev
S2Kev's Avatar
You probably just drained the battery.
Old 02-24-2004, 04:04 PM
Kai
Rotorphile.
Kai's Avatar
Remove the battery from the car.
Charge the battery overnight.
Put battery back in car.
Car will start.
Old 02-25-2004, 06:26 AM
90_crx_flaze
Drift King
The car has power to it i tried charging it and another battery but it still wont work since i left the ignition on ima try another starter might of burned that up
Old 02-25-2004, 04:55 PM
90_crx_flaze
Drift King
i tried a new coil on the distributer cuz my boy had one layin around and that wasnt it and my auto teacher prescribed a new fuel filter, ima go buy an altenator cuz that bitch has been whinin
Old 02-26-2004, 12:06 PM
90_crx_flaze
Drift King
tested altenator that works good if not running a stereo, starter that works, battery and a jump that didnt work, replaced fuel filter that didnt work checked fused and there all good
Old 02-26-2004, 07:49 PM
brokeazzcrx
brokeazzcrx's Avatar
the same thing happend to my 88 crx...drained the battery...replaced all that crap just so happend it was like bad timing...my ecu went...apparently i had a leak and water got into it or something i dunno.. if none of that works.. id give a ecu a try... hope everything turns out ok
Old 02-26-2004, 09:04 PM
S2Kev
S2Kev's Avatar
Now that you've tried everything else. I'd check for the 3 things that make an engine run: spark, fuel, and compression.
Quick Reply: damnit i killed the rex now it wont start
