My Crx has no spark
Old 02-16-2004, 05:15 PM
kirkpatti
kirkpatti's Avatar
Default My Crx has no spark
Ok, my 91 crx si has no spark. I have changed the icm, the battery, the coil, the ecu, the plugs and plug wires All the wires fuses and relays are good. Someone please help me!!!!!
Old 02-16-2004, 06:48 PM
brtecson
pukimonster
brtecson's Avatar
did u check the distributor cap and rotor??
Old 02-16-2004, 06:49 PM
brtecson
pukimonster
brtecson's Avatar
btw, whats icm?
Old 02-16-2004, 11:25 PM
noki-o
slow rex
noki-o's Avatar
its your distibutor the hole think not just cap and rotor you can get one at a junk yard for 130 or of ebay for 200
Old 02-17-2004, 12:23 AM
brtecson
pukimonster
brtecson's Avatar
he said he replaced the coil :dunno:
Old 02-17-2004, 07:49 AM
jc836
jc836's Avatar
Just to let you know-I do have a complete TD-02U distributor sitting here-for sale. If you have changed the module and coil then the problem is in the bottom where you cannot repair it. There are several sensors buried in there. Check for a reddish dust on the components as that is the remnants of the bearing. Our distributors are known to fail with over 100k on them because of this bearing. (If you think that the computer may be bad I have one of those too.) Yes-I do have an OLD thread in For sale and here on Dizzy problems.
The other thing is that IF you can crank the engine it is still possible to have the famous MAIN relay problem. This is easily tested. Be in a reasonably quiet place and listen carefully when you turn the key to the ON position. The Check light should come on and you should also here the fuel pump run for ~2 seconds; the light will also go out. If this test is good and you do not have spark-it is the distributor. BTW: The Helm is your friend for most of the tests.
More questions-drop me an e-mail.
Old 02-17-2004, 03:55 PM
jaje
HC Racer H5
jaje's Avatar
jc836...do you run your car at summit often? i think i've seen you tooling around before but can't place where
Old 02-18-2004, 10:53 AM
jc836
jc836's Avatar
JaJe
Have not had the pleasure at Summit yet-the car does see a lot of time at both The Glen and Pocono. Were you at BeaveRun for HyperFest last year? We will be there more than not this year-home track 1 hour from house <BG>.
Old 02-21-2004, 03:29 PM
kirkpatti
kirkpatti's Avatar
Icm is ignition controle module
Old 02-21-2004, 03:30 PM
kirkpatti
kirkpatti's Avatar
I have checked the cap and rotor and have replaced them.
Quick Reply: My Crx has no spark
