how to change c.v. joint?
Old 01-29-2004 | 08:58 AM
shawn_crx8891's Avatar
shawn_crx8891
Default how to change c.v. joint?
how hard is it to change an inner c.v. joint? i need to use my b16a inner joint on an 86-89 integra axle, but i've never messed with taking one apart. just wondering if i'm going to get it apart and not be able to put it back together. thanks.
Old 01-29-2004 | 03:17 PM
slammed91-hatch's Avatar
slammed91-hatch
sure you need the 86-89 axle? i keep hearing that it's too short and to use the 90-93 one. should be pretty self explanatory to change it once you pull the axles out.
Old 01-29-2004 | 03:50 PM
shawn_crx8891
according to hasport, i need to use the older ones. the inner shaft or whatever is too short on it i guess, so that's why the b16a inner is needed. i thought about just using a 90-93 but supposedly it's not the right size although i've seen a lot of people using them.
98CoupeV6
07-17-2003 09:34 AM
b_dyche
06-05-2003 08:25 AM
Nightshade
06-01-2003 03:12 PM
davekaro
92+ Civic/EL & Del Sol
7
01-07-2003 12:00 PM
Quick Reply: how to change c.v. joint?
