big time tranny problem?
well remember u dont want to push it in you want to pull it out with 2nd gear it is gonna be moving it downward with teh shifter but the opposite happens so ur gonna want to pull it forward, but good luck and i wouldnt use a sledge buddy... just pull as hard as u can. if its not gonna come out then something is bad in the tranny.
PC's_N_CaR_EnGiNEeRiNGMaN
hey, someone i know with a 93 accord had this prob then his clutch pedal stuck to the floor along with it stuck in 3rd, then someone else i know had the 2nd gear stuck in with a hatch 4 spd trannie..... turn outs==== the accord needed trannie/ motor oil in the clutch resovour and all was fine after (he towed it to the dealer ship and they juiced his tail for the work) and on the civic hatch... he drained the trannie fluid in the lot he was stuck in,, poured in lucas trannie juice and 3 brand spanking new quarts of motor oil and it poped right out of gear and all is well... he also told me when he drain the trannie not much came out possibly not even a quart.... so hey check your fluids in the trannie!!! could be but you never know... gluck!
i emptied out the tranny fluid and i twasnt low but def wasnt half way and then i did fill it up again...not with honda mtf which im thinking maybe i should do ;p
