RPMs in your CRX
GWAKS- Tech Geekifier
I run about 3750 RPM at 70, 4k at 75, etc.
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
Rotorphile.
Originally posted by IrradiatedKitty
no, the engine does make a difference.
8000 rpms in 2nd lol will hit about 70 for me... actually not quite maybe 60. 5th gear at 70 is about 2500 with an hf 5th gear, with a zc 1-4, i love my tranny and as it was said b4 it does not matter what car u have the input shaft of any tranny will spin a certain amount of times as the output shaft will turn a different amount depending on what gear ur in, engine makes no difference whatsoever.
Originally posted by Vividkid82
what tranny?
what tranny?
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
RacinMasonC
so tell me this... i had a d16a6 complete engine and at 70 i redline in 3rd gear... i did a mini-me swap (a6 bottom end/z6head) and now 3rd gear brings me to 80. tell me how that works... and yes same tranny, same everything but the head.. lets see this now smart guy!!!
Then the speedo has to be off or you remember it wrong.
Changing the head didnt change gear ratio, but if your redline went up, obviously your going to top higher in each gear...
Z20 H8R
i looked today at what i was at...my vafc said ~4000K but then again my speedo is off...but i dunno how much.
i changed my head, and reprog'd the ecu so it redlines at 9g. i dun think i have a higher topspeed though. cant know for sure b/c my speedo only goes to 120. i need a rev speed meter..apex'i makes a good one that has options like: aftermarket wheel size, 0-60, 1/4 et, 1/8 et, 60-0, and is really accurate when used with the g-sensor b/c it compensates for wheel spin. if you are really worried bout your speed buy one of these. they are 306$ shipped with the g-sensor. http://www.inlinefour.com
it looks like that but with rpm's and speed not throttle position...
