View Poll Results: Which 1 for Road and Strip
B16A1/2
2
25.00%
B16B
0%
B18C1
2
25.00%
B18C5
0%
B20Vtec
4
50.00%
Voters: 8. You may not vote on this poll
Best swap for my plan
Old 10-26-2003, 11:29 PM
Kai
Rotorphile.
Kai's Avatar
Alright, here goes.
B16A1/2: too weak.
B16B: too expensive and too weak (torque wise.)
B18C1: Best choice, if you can afford it.
B18C5: Too expensive.
B20Vtec: Too expensive, but if you can afford to build it well, it would outrun of any of the other options.
You also have to decide if you want a track car or a drag car. They are completely different in configuration.
Old 10-27-2003, 05:02 AM
GsrRex88
GsrRex88's Avatar
A b20 vtec or a b18c5 arent to expensive....
-Eric
Old 10-27-2003, 05:35 AM
jaje
HC Racer H5
jaje's Avatar
A built for forced induction b18b turbo (~250whp) would easily fit the bill. They are cheap and you can find used turbo kits with some searching. That'll get you much easier into the 12s and with proper tuning (fuel and timing) and a good cooling system (water cooled turbo, oil cooler, and even a trans cooler) make it a not so bad road racing engine either (turbos make an engine run much hotter)
Old 10-27-2003, 11:48 AM
Kai
Rotorphile.
Kai's Avatar
Default Re: Best swap for my plan
-Eric
B18C5 swaps float around $4-5k, and add to that all the hardware and electricals you need to make it work in a CRX body, you're looking at least $5k. That's a lot of money. Same with the B20VTEC hybrid, if you want a good solid motor you need the block, head, rods, a crank girdle, new valve springs, and the oil lines. On top of that, you still need a transaxle, the mount kit, and the proper electricals.
I admit that I missed this line:
Originally posted by Africanqueen
Money is not a problem for the swap.
If money is no object, B20VTEC is the way to go.
Old 10-27-2003, 01:27 PM
GsrRex88
GsrRex88's Avatar
i hate it when ppl say "money is not a problem"
Like WTF did they just win a lottery or are they taking out a house morage to build this thing or something.
If money is no problem just buy 10 crx's and do everysway you can think of than scrap the ones you dont like.
-Eric
