ZC tranny QUESTION
ZC tranny QUESTION
alrite i have a DOHC zc stamped with the date 87, and i have a 90 crx si tranny. the zc didtn have a transmission on, so im assuming that i just stick my si transmissin on it? well i dont think it will go on there, because teh clutch disk seems to be different? so could i just unbolt the zc one and put on my si one? do i need to switch flywheels too or does it even matter? i dont want to try and have it not work and have to take it all apart again. so any help with how to get my si tranny to work with the zc. i thought i just swapped it in but i guesse not. thanks
you have 88 ZC engine and if it still has the stock clutch, it has 21 splines - your 90 Si transmision has 20 splines - yes, you need to swap flywheels - the 88 clutch is only 190 mm diameter, the 90 is 212mm - 90 clutch won't work on 88 flywheel
well the clutch bolts up to the flywheel. it looks the same..doesnt look that off? but i didnt measure it. so your sure. man how do i get teh flywheel off those nuts are on there hella tight.
the flywheel looks to be exact. are you sure i cant just use the zc flywheel and put my si clutch shit on it? also when puttin the clutch on do i need to align anythin really, or can i just bolt it on and put the tranny on?
