2003 Acura TL type s/power windows ,sunroof,electric seats and dashboard gauges don't
Car starts fine,but electric windows don't work,sunroof doesn't work,electric seats don't work, and dashboard gauges and indicator lights don't work.car runs fine though....checked all fuses.changed burnt out ones.everything worked again.two hours later went to roll up windows and same problem...
Since you said the LED in the switch isn't working it makes the diagnosis pretty easy if you have a wiring diagram, because the wire that supplies voltage to the LED also supplies the power for the switched side of the relays built into the rear window switch.
IntegraR
09-29-2004 09:16 PM
