System F****cked Up Again
Old 10-16-2003 | 09:22 AM
DJ Scotty's Avatar
DJ Scotty
Originally posted by 97teg
yes 800 is split between them so each will be getting 400 watts. I personally don't like groundounders and think thats how you get your system stolen and damage yoru hearing imo. Anyways as i see it you have two choices different box, ported or bandpass but you need it tuned kinda high and a sub sonic. Probably won't sound good but will be loud or the other option is to go with a different speaker maybe something that is a bit more expensive. You might want to ask around on www.soundillusions.net or www.caraudioforum.com they will probably be able to help you out more than i can.
Thanks Teg.
Old 10-27-2003 | 10:27 AM
moofoo's Avatar
moofoo
Tastes like DonkeyBalls
Old 10-27-2003 | 10:33 AM
DJ Scotty's Avatar
DJ Scotty
Originally posted by moofoo
Oh man----lookie lookie here......as if I ever thought I was going to leave your precious, imbecilic thoughts....how are you, monkeyballs? Man, you need to be congratulated....hold on....Im getting my violin band....:jerkit: :jerkit: :jerkit:
Old 10-27-2003 | 10:34 AM
DJ Scotty's Avatar
DJ Scotty
Whoops!! Did I say MONKEY balls? I mean DONKEY balls!!
Old 10-28-2003 | 09:06 AM
moofoo's Avatar
moofoo
wow such an outburst from a simple emoticon.
382 posts and 300 of them about the same 'ol whining and moaning about how his car feels old and his sound system is sub-par. Hence why I to this and ALL prior countless threads created for the sole purpose of having nothing else to talk about...
Old 10-28-2003 | 01:08 PM
Spyfunkr's Avatar
Spyfunkr
Bass is mostly unidirectional, but try firing the subs forward. Is the seatback down? The sound waves do need a way to travel, if they're enclosed in the trunk, that may not happen. A ported or bandpass box would also help, as DJS said.
As far as that line-out converter, ditch it and get a real head unit. Who knows how much impedance your adding and how much the voltage levels are reduced. With a Alpine unit, youll get at least 4v pre-outs and frequency cut-off control.
-Spy
