Weird car audio problem
the fuse box is one the the noisiest(electronically) places in ur car u should definately move it to the back of the stereo or the cigarette light which is where i have mine hooked up...also which speakers is the whining coming from? do u have stock speakers? or perhaps aftermarket tweets? and do u have an amp running the speakers?
check to make sure you have resistor spark plugs. I know you can get a whine from not having the right plugs. I agree with the other guys....Make sure your power wire is run as far away from you RCA cables as possible. Too close will definetly cause engine noise. Just my 2 cents.
