How low can I drop a 6th gen without a camber kit
what is the low can I go on my 6th gen just got for a steel at $7200, I thinking about 18's or 19's but i want enough ground clearance to go over speed bumps........ I rides like butter vtec is killer ........ Ohhh and whats the lowest I can go without having to get a camber kit........
Originally posted by insanelylow
so will 1.75 give me enough clearance with 19s and a bodykit
Originally posted by see_fu
1.75 you'll need camber. I dropped w/ the 1.75 kit from H&R and I needed a camber on the rear.
Depends up on how bad is your camber after lowering
the car..
I would say.. for safe side.. get a camber kit. or
go with H&R OE spring...
Approx..
Front: 0.75
Rear: 0.75
my back dropped 2" on a 6th gen and i can see the camber is not looking healthy. I do get the drift car look though =) If u don't want a camber kit a non-directional tire would be a good choice. I wish i would have bought yokohama paradas instead of the avs since the avs needs to be taken off f the rim to rotate to other side. I think frequent rotations would save ur tires with out a camber kit.
