How to remove front control panel?
Old 09-12-2003 | 03:11 PM
blaksun's Avatar
blaksun
Default How to remove front control panel?
Does anyone know how to remove the front control panel that holds in the radio, and air condition system where the dial are located at. It's the plastic cover that has two screws on the bottom of it. I need to replace the light that controls the power of the A/C.
It's for a 99' Honda Accord Coupe EX
Old 09-12-2003 | 04:35 PM
buster133's Avatar
buster133
Default removing panel
First remove the clock/hazard switch cluster by gently prying up on the bottom edge of the panel right below the clock. There is one screw hidden behind the clock, then remove the other two screws at the bottom, the gently remove the whole center panel.
