Help Quick!!!!!!! Spark Plug Wires.
Type S & Accord
Went to install new wires and noticed after I pulled all out that they are not marked on the rotor cap like on the wires.. Help please anyone, they are completely miss firing. I have 96 Accord LX.
Honda Biased
thats why you change ONE wire at a time...i would help you but i have no idea how to tell which one goes where..sorry man! Anybody else? Each vehicle might be different. BUT..you can do the process of elimination..just try EVERY combination ok? for 4 cylinders...its 4x3x2x1...so you are going to have 24 different combinations i THINK...someone correct me if i'm wrong.
Dave
Dave
THE RED 6th GEN Coupe
Assuming you are same as F23 in gen 6 this is the pattern.
Bottom left when looking at cap 1--bottom right is 2-- top left 3--top right is 4.
3-4
1-2 --is the gen 6 4cyl pattern.
Try this for your gen5, they are likely the same I would imagine.
3-4
Type S & Accord
Figured it out. There's one marking on the rotor cap that starts the 1 then 4-3-2 going clockwise. In case anyone else has this problem and does a search.
Honda Biased
Jizz Maste12
what you can do is pull out ur sparkies and sick napkin in to the sparkplug holes and ask your friend to crank the engine and you would have to do this a few times each time u crank the cyc. will pop the napkin, in correct order
Honda Biased
I'm sure i misunderstood, could u please explain in further detail? thanx!
Dave
