Fuel Pump for Accord???
Re: Fuel Pump for Accord???
Originally posted by Sleeper00
i have 92 accord with H22A motor and i need a higher pressure fuel pump, which kind of fuel pump should i get with the H22A motor, and where is the fuel pump locates at??? thanx
Why do you need a bigger fuel pump?? I run the stock one on mine and its got pretty high compression and fuel consumption.
You don't know where your fuel pump is but your sure you need a bigger one?? Have you tried a fuel pressure regulator instead? It may solve the problem you think your having instead of forking out for a performance pump.
the reason i want to get a bigger fuel pump cos i put in H22A motor in my 92 accord, and i think i need to upgrade the fuel pressure that's y i want to get a bigger fuel pump. is there an other way to make the fuel pressure higher?? is it a big job to change the pump?
You wont need a higher volume fuel pump if your running a mildly modified H22. You'll be good with a fuel pressure regulator. It allows you to adjust the fuel pressure going to your motor. Changing the pump is straight forward. You gotta drop the tank though but once you have it off you can get to the pump and replace it with ease.
Currently I am running a highly modified H22 in my 5th gen and am also currently without an FPR on stock fuel pump....does just fine for me but when I race the FPR would help me out a bit, although still not completely neccesary.
