Need help installing my Amp and Sub.
I have a 10 inch Amplified Bazooka Tube. Does anyone know the BEST way to hook it up to the stock Accord V6 system. Do I unhook the rear speakers and use the speaker wire or do I splice on to the rear wires and keep the rear speakers plugged in? Or is there a better way. I would rather not loose the rear speakers.
the rear speakers use HIGH OUTPUTS you'll need the RCA converter so you can convert it to Low and to run your RCA jacks into the AMP. That is the BEST way using the STOCK HU. You might need a filter for it too... becuase sometimes those converters dont work wright.
cx power!
Originally posted by dantastic
most amps have speaker level in. you dont need an RCA converter. you can splice into the rear speaker wires in the trunk (so u dont have to run them to the hu). if the sub has "auto sense turn on" you dont even need to run a turn on lead from the hu. the amp should have a "low pass filter". you dont want those high sounds going to the sub.
cx power!
Originally posted by midnightrider
Yes, the Bazooka Tube has speaker level inputs with a low pass filter. So can I just splice onto the rear speaker wires and still have the rear speakers hooked up, or must the speaker wire run only to the Bazooka Tub Amp?
cx power!
Trust me tapping your rear spearker high's to your amp will give you shitty audio quaility you'll get alot of background noises.
