Window problem
Old 04-17-2003 | 11:06 PM
accordlx's Avatar
accordlx
Default Window problem
OK so its the first day that i have my 93 lx 5 speed and i love it, however i noticed that wind was getting in to the car through the top left corner of the driver window. The windows are automatic and i tried several times to just keep putting it back up and it wont shut all the way, i thought that maybe the window is misaligned? if anyone has ever heard of this or knows what to do please respond
Old 04-18-2003 | 03:31 AM
hype8912's Avatar
hype8912
Dr. Klaw
The same this has happened to my passanger side rear window. The back ones are cable driven and the plastic piece at the top that the cable slide throught broke not allowing the cable to go high enough. You can try taking the door panel off and push the window up. Since mine was a back window. I just got it up as far as I could and took the fuse out so nobody could roll it down. I've seen the new regulators on e-bay for 54.95 if you wanted to go that way. Or you can let a local shop look at it and give you an estimate.
Old 04-18-2003 | 06:11 PM
accordlx's Avatar
accordlx
Thanks man ill check that out.
Old 04-18-2003 | 09:08 PM
accordlx's Avatar
accordlx
I figured it out, when the window rolls up it was bending in the outer molding, and the molding was acting like a ramp off track for the window. Now i just have to figure out someway to stop that@
thanks again hype!@
