H22 in 92 Accord, Please Help!!
use the accord axles, accord mounts, accord harness add 2 wires and a ground for vtec, one wire for knock sensor, and unless you had an ex or se you need to add one wire to the ecu for the IAB and one from the IAB to power. I was able to make my stock harness fit the h22a without mods on my 92 lx then just added the extra wires.
also you need to change the EGR plug to the round prelude one and change the push on connector on the oil pressure snesor to a eyelet that screws in.
the H22 motor that i m getting comes with the Tranny, ECU and the Clutch, that's all, and its costs $2600 + shipping, from streetimports.com is there any other wed site that has pretty good prices? where did u order ur engines at? if i can use the accord motor mount, axles and the stock ecu wiring harness just all more wires, that's great, what about the SHIFT LINKAGE? do i have to use the prelude shift linkage? how about the A/C compressor, accord compressor or prelude compressor? i m ready to order that H22, just want to know more about it so i can get all the parts together, i really appreciate u ppls help. if theres more info it will b better,
try hmotorsonline.com they have one for 2100 plus shipping, but I want to know from anyone is what motor is better the h22 or the f20b and will the f20b mount directly into a 90 lx coupe.
thanx for ur help ppl, i think i m ready to order that H22 motor, who got the best price, so far hmotorsonline.com is got the best prcie, who else sells honda motors??
