Will Doing 9005 conversion burn out harness?
I just ordered some 9005 krypton bulbs off ebay and was going to do the 9005>9006 conversion. But then I started to think, is there anyway the higher watt bulb could burn the harness. I remember my friend had some cheap brand in his 94 accord, (they were 9006, even less watts) and it ended up burning out his wiring harness. I dont want to put them in if there is a chance of that. I was actually going to buy hid's, but bought something else instead. So hid's will eventually be in my car, this is just a quick fix. Thanks.
Your stock low beam wiring is designed to handle 4.07 amps of draw.
So if your new 9005 bulbs draw more then that you could have a problem.
Devide the wattage of the bulb by the operating voltage and you will get the amperage. For example 55 watts (9006) devided by 13.5 volts = 4.07 amps.
You could also do a final test using a multimeter. If it draw slightly more for example 4.25 amps it shouldn't be a problem but I would consider using a relay to power the lights.
The light is still focused. I did the conversion after I did my black housings so I had already elimanated most of the scatter. But I don't think anybody has complaints about them. At most you might aim your headlights down a tad.
