9005 Conversion Question
Just to let you know, you don't have to modify the 9005 bulb to fit the 9006 socket. A lot easier method is to modify the 9006 socket to accept the 9005 bulb.
OK, OK, it's not really bad as it sounds....In the 9006 socket, there is a plastic piece that prevents the 9005 bulb from fitting. All you have to do is get a small needle nose pliers and remove the snap in clip. Once you remove it, you can fit the 9005 in there, you can also put the 9006 in there also.
Remember to save the clips, if you ever want to put them back in. BTW, I did this on a 96 Accord with Sylvania Silverstars and saved the 2 clips into a ziplock sandwich bag.
