Silverstar 9005/9006 Conversion Questions
Old 02-24-2003 | 02:39 PM
  #41
jtown's Avatar
jtown
would you guys be so kinda as to write a review on those silverstar bulbs?
Silver Star Review
Thanks fellas!
Old 02-24-2003 | 02:45 PM
  #42
illusion's Avatar
illusion
Originally posted by DownLowAcc
so are those Silverstones just super white? or are they "HID look"? they have a tint of blue or purple in them? I was thinking of getting those.
mine?? not silverstars, not "HID look", and no tint, they are philips 85123 D2R(Same bulb a lexus uses I think) re-based to 9006, with philips ballasts w/ integrated ignitor(lvq-212). They are real HID.
and to monstar's first post, 9005 in low beam on an accord ins't that bad because of how they shield it, some cars rely on the shield of the bulb itself to reduce glare, not accords. As far as 9006 in high beam, it wouldn't work well because a 9006 is a capped bulb. It would be significantly more dim than a 9005.
Old 02-24-2003 | 02:50 PM
  #43
JDMCivic
Guest
Posts: n/a
Originally posted by illusion
and to monstar's first post, 9005 in low beam on accordn't ins't bad because of hose they shield it, some cars rely on the shield of the bulb itself to reduce glare, not accords. As far as 9006 in high beam, it wouldn't work well because a 9006 is a capped bulb. It would be significantly more dim than a 9005.
Only good thing about 9006 in the high beam area is if he wires it up to be day time running lights. Other then that I wouldn't recommend it.
