Accord 2000 SE power door locks problem
Old 02-23-2008 | 12:06 PM
nacnud777's Avatar
nacnud777
Default Accord 2000 SE power door locks problem
My 2000 Accord ES door locks dont work here are the symptoms:
When either the master door lock switch on either passenger or driver side is operated each door actuator responds anc tries to move the look. this happens in both up and down directions. ALL four actuators behave exactly the same way. the relay behind the right side kick panel is clicking. same happens when key less entry is used. so the switches appear to be ok. the relay is clicking but why isn't full current getting to the actuators? any ideas out there?
Old 02-24-2008 | 07:04 AM
Tedmond's Avatar
Tedmond
over time the actuator starts to stick, and doesnt work efficiantly as it used to. you might end up changing the relays as the relays could have gone bad. its rarel but does happen.
Old 02-24-2008 | 08:04 AM
nacnud777's Avatar
nacnud777
i could see one or two actuators going but not all 4 at the same time. if it is the relays. where are they located on this vehicle. i could not find them
thanks
