Timing Belt Change Parts
i am about to order the parts and just wanted to check if i was missing anything here are the parts i got so far:
- Timing Belt: 14400-PT0-004
- Timing Balancer Belt: 13405-PT0-0004
- Power Steering Belt: 56992-P0A-J02
- Alternator/Compressor Belt: 38920-P0A-J02
- Water Pump: 19200-P0A-003
- Front Balance Shaft Retainer Kit: 06923-P0A-306
- Valve Cover Gasket Kit: 12030-PT0-000
- Timing Belt Adjuster (Tensioner): 14510-PT0-004
- Timing Balancer Belt Adjuster (Tensioner): 13404-PT0-004
- Timing Belt Adjuster Spring: 13407-P0A-000
- Timing Balancer Belt Adjuster Spring: 14516-P0A-000
- Hondabond High-Temp Silicone Gasket Sealant: 08718-0001 (Can't Find this)
is there anything else i need for the timing bet change thanks
i have a 1995 honda accord lx
not sure if it's already included in ur list, but i believe one of the seals may not stay on tight once it's been replaced, so honda recommends also buying/installing a little contraption to do that. the dealer should know what im talking about.
they make a little bracket to go with that. the bracket came after the these cars were already produced. some of those seals poped out on thier own.
The bracket is super cheap at the dealer, like 5 bucks. make sure u get that too
