1998 Honda Accord Door locks/alarm
Old 10-06-2007 | 11:07 AM
Fatfenders's Avatar
Fatfenders
Default 1998 Honda Accord Door locks/alarm
It's my wifes car so it's more important than if it was mine.
The door locks won't lock using the remote control. The light on the steering column flashes and the little beast is alarmed but the doors aren't locked, you can lock them manually and you can unlock the drivers side remotely but not the other doors. I can hear a click in the drivers door when the remote lock button is pressed. Is there a relay or something that has failed and if so where would I find it? Thanks in advance ... if I fix this for her it could be a great weekend.
Soooo after two days it decides to work again, I think it may have just taken the weekend off.
Last edited by Fatfenders; 10-08-2007 at 06:01 PM. Reason: Added more information for clarity ...
Old 12-18-2007 | 07:59 AM
sevenkruwer's Avatar
sevenkruwer
I got the same problem. Have you figured out something?
Old 12-18-2007 | 01:53 PM
nspec_Cd5's Avatar
nspec_Cd5
spray some GUNK lubricant spary in there if u can take the panel off.
Old 12-19-2007 | 06:14 AM
sevenkruwer
I decided to go to Honda dealer yesterday and ask what they think. They mention something about actuator and not forget about the cost to diagnose the problem too grrr...about 100 bucks.. I ll check actuator and spray it. I ll let you know what happen
Old 12-22-2007 | 09:59 AM
Hiroshi's Avatar
Hiroshi
This is happened almost everytime when very wet condition. When it's drying out, problem is also gone away. How about yours?
Old 12-22-2007 | 12:21 PM
sevenkruwer
i just installed mine recently and it has never able to lock at all. I said, i was going to gunk it. Unfortunatelly, I havent had time yet. I ll keep you guys update when i get it done. Is there anymore alternative, in case spray the "GUNK" does not work?
Old 12-22-2007 | 03:15 PM
nspec_Cd5's Avatar
nspec_Cd5
u'll have to open it up and manually test the actuator
