DIY MDF baffle for front speakers
Old 03-24-2003 | 05:17 PM
lilboi's Avatar
lilboi
any one got some actual pictures of these baffles or spacers. What is better making a totally new baffle or adding a spacer. Last week i tried making a new baffle i still won't clear the window. I made it out of 3/4 inch wood. I tried this so many times, im starting to give up. I could make it out of 1 inch wood but i think then it's way to thick. I tried putting my baffle on top of the stock one, i coun't close the door. So i think the spacer ring is the best way. Then seal it up with some cocking. Any one got a place to find noise damping for a good price.
Old 03-25-2003 | 05:56 AM
moofoo's Avatar
moofoo
Tastes like DonkeyBalls
These are some profesionally fabricated ones.. but u get the idea
Old 03-25-2003 | 10:14 PM
lilboi's Avatar
lilboi
i can't afford the good shit. I had to make it myself with mdf i found at the homedepot and some i had laying around. What i did at first is trace the plastic baffle on to 3/4 mdf and then cut it with a jig saw. Then i found some 1/2 mdf and made a spacer out of them. I drilled holes and held the baffle and the spacer together along with the speaker. So it's the speaker ontop of a 1/2spacer then a 3/4 baffle. It fits good. i had to use my dremel and shave a little off my panel but i don't mind for a clean sound. I only did one side so far. I will do the other side when i regain my stregth. I wish i could take picutes but i will do that next time. Later i'm going to put some cocking on the edges so no sound leaks through making less of a rattle when i booste it up. i screwed it tight to the door so i doesn't rattle. Sounds nice. I have the alpine SPR-175A. They have a HUGE magnet. when i say huge i mean huge. it's like twice the size of a stock. I would just buy a jig saw($30) and some mdf($5). It's a very cheap costing job for a nice sound. If you go to good guys they do sell 1'' spacers. It cost 17 dollars for a pair though. so i would just go out and buy my own supply's.
