4th Gens. with cooler thermostat?
Hey everyone, for those of you with a cooler thermostat... where did you get it and how much did it cost? I know the stock one is 180-degF, looking for the next lower which I guess is a 160-deg one. Thanks for your help!
-- Steve
-- Steve
I found one here (www.accordstore.com) for $11.20, search for Thermostat. It says it's 160-deg, but also that it is a replacement. I suppose it's worth a try for only $11.20. FYI, the stock part number for the thermostat is the same for 1990-1997, so any one will fit...
Try www.kingmotorsports.com. They're pretty pricey - $69, and you have to swap out the fan switch at the same time for another $45.
