Gas Mileage Help
Old 06-21-2007 | 05:24 AM
Johar's Avatar
Johar
Maybe an alignment?
Old 06-21-2007 | 12:21 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
I'm currently getting about 450 miles and a full tank
AC doesn't effect much MPG, i think the biggest factor that effect MPG is
Your left foot
whenever you accelerate go SLOW, image ur foot as the seconds hand on a analogue clock, if it moves any faster.. your wasting gas. If you keep that in mind you can save a lot on gas.
and then Faulty Oxygen Sensor..air filter..
Old 06-21-2007 | 03:26 PM
Misa's Avatar
Misa
Pic Whore
left foot?
Old 06-21-2007 | 04:12 PM
autofreak's Avatar
autofreak
Last time I filled up I calculated 24.9 combined mpg for my '05 auto 4 cyl Accord......is that about what you other 7 gen. owners are getting? I use the a/c all the time being that I live in Texas and do all my shifts below 2,500 rpms.
Old 06-21-2007 | 05:28 PM
scotttharobot's Avatar
scotttharobot
beer here
Your left foot
clutch does all that? whoa...
On Topic...
I was getting like 17MPG city in my 94 Protege, automatic. I was pissed. It turns out I was just driving it too hard from a dead stop. I didn't really think I was, but then I began to take it easy when I started from a dead stop, and got about 25mpg consistently (city).
Maybe you are just driving it harder than you think you are.
Old 06-21-2007 | 06:53 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Originally Posted by b12uceHuy
What you'll need to do is cal. the MPG. I think our tank holds about 17.8 gallons.
fill up your tank FULL, reset the trip Odometer drive till your gas light turn on.
Fill up your tank and write down the number of Gallons actuall USED.
Mileage on Trip Odometer/Acutal Gallon filled up=MPG
IE: 240miles/15gallons=16MPG
It's ~14.7 gallons.
Old 06-21-2007 | 07:45 PM
Misa's Avatar
Misa
Pic Whore
Originally Posted by totalimmortal
It's ~14.7 gallons.
its 17.1
Old 06-22-2007 | 11:04 AM
scotttharobot
beer here
My accord has a ~17 gal tank...
Old 06-24-2007 | 07:12 PM
qsd_Dan's Avatar
qsd_Dan
Remove your intake air temperature sensor and clean the tip with carb cleaner and a rag.
The IAT sensor gets gummed up from crankcase vapors and over time forms a coating over the sensor tip, causing the sensor to give a false temperature reading. I clean mine every other oil change.
Old 06-25-2007 | 07:09 AM
totalimmortal
MalleusMaleficarum
I've never been able to put more than 14.5 gallons in my car on a fill up, running on fumes kind of fill up.
