97 accord ex electrical problem
Fixed the problem, it was some bare wires behind the control panel. Come to find out there is a recall/tsb on this problem. The honda bulliton# is 98072. Thanks to all that replied. This is what the bulliton says DEALERS WILL INSPECT THE VEHICLES FOR PROPER ROUTING OF THESE WIRES. ANY HARNESS IMPROPERLY ROUTED WILL BE INSPECTED FOR DAMAGE AND THE ROUTING WILL BE CORRECTED. IF ANY INSULATION IS WORN THROUGH AND THE COPPER WIRES ARE EXPOSED, THE HARNESS WILL BE REPLACED. DEALERS WILL ALSO INSTALL PLASTIC TUBING TO PROTECT THE HARNESS.
You need to have your vin# ran at the dealer to see if this applies to your vehical.
