what's the best way to diagnose suspension noise?
Old 03-26-2007 | 09:31 AM
oholdeno's Avatar
oholdeno
Default what's the best way to diagnose suspension noise?
i'd like to finally get this fixed but not sure how. i'm on koni yellows and eibach pro kit springs.
it basically sounds like a 'koon koon koon' sound as if something is loose when i go over bumps. i've checked all four tires and there is no lateral play in them. the rear sway bar is not loose.
from what i can tell the noise comes from the front and rear.
Old 03-26-2007 | 10:00 AM
flyromeo3's Avatar
flyromeo3
Have you checked your strut mounts.
Old 03-26-2007 | 11:51 PM
wedley2's Avatar
wedley2
bboy Wesley West
yea, check the top nut holding the strut down.
i know mine on a 88 camry had to be torque down via impact wrench 1" worth of thread
Old 03-27-2007 | 06:27 AM
flyromeo3's Avatar
flyromeo3
I went through the same thing with my struts. About 5 months after install I needed to retighten that bolt and noise is gone.
Old 03-27-2007 | 01:20 PM
oholdeno's Avatar
oholdeno
thanks i'll give that a try, it does sound like it's coming directly from the shocks somewhere. i know they are not blown.
Old 03-27-2007 | 01:43 PM
oholdeno's Avatar
oholdeno
will this require removing each shock from the car? how much will it cost to get this done at a shop?
Old 03-27-2007 | 07:25 PM
oholdeno's Avatar
oholdeno
so i popped the hood and all of the nuts seem to be down pretty tight but it's somewhat hard to tell because they are rusted kinda bad. what do you guys think i can do from here?
Old 03-28-2007 | 09:02 AM
flyromeo3's Avatar
flyromeo3
hhmmm......
I've never tried this but you think jacking up that side of the car and playing with the wheel " by moving it up and down with the shock " would duplicate the noise?
Old 04-02-2007 | 08:27 PM
oholdeno's Avatar
oholdeno
hi guys i have a good feeling it's because of the eibach springs progressive design.. some of the dead coils are hitting each other. i'm going to try to stuff some cardboard between the coils and see if it sounds any different. if it does, then i think that'll be the culprit.
