blown fuses help
Old 03-24-2007 | 05:27 AM
noypi's Avatar
noypi
Default blown fuses help
i was driving home when instrument cluster lights along with my backlights. i checked fuse=but ok- i checked fuse for small lights in engine bay was blown i replaced but keeps blowing- anyone have idea if there is another relay that controls lights- i know i got a short somewhere-hope someone can help thanks
i found the short its the r/turn signal wires were open-could it have shorted the whole harness since my front headlights are always on and the fuse keeps blowing
Old 03-24-2007 | 09:01 AM
RKV's Avatar
RKV
what yr accord do you have?
Old 03-24-2007 | 09:12 AM
teg92's Avatar
teg92
WHAT OK YEAH!
seems like you have a short somewhere
Old 03-24-2007 | 09:14 AM
Shockwave895's Avatar
Shockwave895
this probably wont work but i had the same problem with my 90 ex-found out that my little nephew was in my car and put a penny into my cigarette lighter and it kept blowing my fuses. Probably doesn't help but you never know.
Old 03-24-2007 | 08:47 PM
stereo's Avatar
stereo
if the radio is aftermarket pull it and check the dimmer lead red/black is caped off or taped and not touching ground.
Old 03-25-2007 | 08:27 AM
noypi's Avatar
noypi
Default still blowing
i grounded turn signal still blowing fuse, check the radio red/blk wire is ok taped up- now my throttle position sensor is on- its the saem side harness as the turn signla-anyone have etm so i can fault trace this wire harness-not sure which wire its on the interior fusebox-it thinks in the grey wire plug on top of the fuses=hope someone can help thanks
