99 Accord EX 3.0l v6 change rear hub assembly
Old 02-11-2007 | 10:52 AM
ric31id's Avatar
ric31id
Default 99 Accord EX 3.0l v6 change rear hub assembly
Any info on changing the rearAxel bearing and hub assembly would be appreciated
Old 02-11-2007 | 02:23 PM
Fuse's Avatar
Fuse
Take of you brakes.pop of the cap on the rear hub and take off the the spindle nut.Do you have the hole assembly?or did you get them separate?
Old 02-11-2007 | 02:31 PM
ric31id's Avatar
ric31id
have the whole assembly, do you know what the recomended torque to apply when replacing the nut?
Old 02-11-2007 | 02:32 PM
Fuse's Avatar
Fuse
Let me pull some shit up will be back in a min.
Old 02-11-2007 | 02:40 PM
Fuse's Avatar
Fuse
read me.very easy.
Old 02-11-2007 | 02:41 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
spindle nut is 139 ft-lb. You should have to replace this because you're supposed to ding the side of it to ensure that it doesn't back off, so if it's factory it'll have that ding in it. You could reuse it but I wouldn't, they're cheap.
98CoupeV6's Avatar
98CoupeV6
what is that from, fuse? it doesnt look like a helms but has the same drawings
Old 02-11-2007 | 02:44 PM
Fuse's Avatar
Fuse
i cant say.
Old 02-11-2007 | 02:49 PM
ric31id's Avatar
ric31id
Thank you Fuse, Coupe. Can't really see the diagram very well though. I think I'll be able to get the basics though. thanks again!
Old 02-11-2007 | 02:52 PM
98CoupeV6's Avatar
98CoupeV6
Originally Posted by Fuse
i cant say.
and why is that?
