Need Help
Need Help
I know this is going to sound dumb but I can't get my key out of my ignition...the ignition lock is brand new the key is brand new (came with the lock) car starts fine but the just wont come out...I've had this car for four years now without any problems this is in fact the frist problem i've had so if anyone can give me anything new to try I'd be very thankful.
do you have 98-02 accord 4 banger four door or two door their is a recall on the lock for that problem the dealer will rebuild the lock.(its free).you can call your dealer and see if your car is in the vin range.the interlock rod gos bad.there might also be an ignition switch recall.if you don't have a 98-02 something is wrong you should not be able to pull you key out if it is not in park your car could roll away.
Thanks I think I figured it out now that I've had a few days to figure it out...Is there a channel on the steering column? (S/P) if there is I think I just need to move the ignition lock...Here's hoping...by the way it's a 94 EX sorry I thought I said that one...
