Lucas Transmission fluid additive
i was changing my motor oil and filter and once i was done, i noticed i didn't buy the right lucas additive. i put tranny fluid additive into the motor, will this harm it?
Perhaps. Motor oil can be used for tranny fluid but tranny fluid is far too thin for the motor, so you might have thinned out the fluid significantly. Change it ASAP and try to avoid oil additives. Totally unncessary for Hondas.
lemme get this straight you put tranny fluid additives in your motor?
Change your oil and filter. Run it for a few minutes. Change your oil and filter. Run it for a few minutes. Change your oil and filter.
Just to play it safe.
