Difficulty of Replacing Rear Shocks on 1992?
Old 10-16-2006 | 07:51 PM
gulfview's Avatar
gulfview
Default Difficulty of Replacing Rear Shocks on 1992?
How difficult is it to replace the rear shocks on my 1992? Could I possibly do it by backing the car up on my ramps? Please advise.
Old 10-16-2006 | 08:27 PM
Misa's Avatar
Misa
Pic Whore
uhhh..... replacing suspension involves taking the wheel out.
there are a few writeups... do a search.
Old 10-17-2006 | 02:07 AM
TypeG's Avatar
TypeG
http://www.cb7tuner.com/vbb/showthre...light=lowering
later.
Old 10-17-2006 | 09:44 AM
mycb7com's Avatar
mycb7com
The car will need to be on jack stands. You remove the wheel. Remove your trunk to get to the top of the shock where there are 2-3 nuts holding the assembly in. Then you take the bolt out of the bottom of the shock assembly and it should fall out. After that comes the dangerous task of removing the spring. Wear safety glasses and aim it at your friend
Old 10-18-2006 | 05:29 AM
you'll need a spring compressor. If you have no idea what you're doing, I wouldn't even bother.
Taking a spring to the face could hurt.
Old 10-22-2006 | 11:23 PM
Dnguyen242's Avatar
Dnguyen242
Noob
I did that for my car rent good stuff for spring removel that the hardest part. I would take you about 3-4 hour if you dont know what you doing. and the other part would be removing your back sits so remove them frist befor you do any thing.
