Radiator problem
Old 03-29-2007 | 07:05 PM
simplyredvw's Avatar
simplyredvw
Originally Posted by AJē06
Bleed the cooling system... might help.
I would start with this response first, although your thermostat may also be giving you some grief.
Old 04-02-2007 | 06:45 PM
ksolo101's Avatar
ksolo101
y are you going through all this trouble? take it to a mechanic!
Old 04-04-2007 | 06:18 AM
tonyEazy's Avatar
tonyEazy
JimBlake, I did what you told me and it was that fan swith, Thanks a million!!!!
ksolo101 I know what your saying, but I like to work on my car even though am not a mechanic.
Old 04-04-2007 | 06:39 AM
AJē06's Avatar
AJē06
I think thats what I need to get .... fan switch or relay... or both? my fdans never turn off... even when the car is on the blue temp in the winter... gaah... HELP
Old 04-04-2007 | 11:22 AM
tonyEazy's Avatar
tonyEazy
Originally Posted by JimBlake
The fan switch in the thermostat housing is responsible for running the fan when the engine is running. Follow the lower radiator hose towards the back, underneath the intake duct. Unplug the 'sensor' in the thermostat housing, and jumper between the 2 wires with a paperclip. Key on, that should run the fan. If it DOES, then everything is OK except that fan switch that you just unplugged. Get a new one.
If that doesn't run the fan, come back & we'll go on from there.
The sending unit for the dashboard temperature gauge doesn't have anything to do with switching the radiator fan.
ps... The other fan switch at the upper radiator hose, that one's responsible for running the fan after the engine is turned off. That one seems to be working OK.
YOu should do what JimBlake said with the paper clip and test the sensor's on both you the upper and lower radiator hose to see if it's you switch. It's a simple test takes 1 min.
Old 04-04-2007 | 03:07 PM
JimBlake's Avatar
JimBlake
YOu should do what JimBlake said...
Could you tell that to my daughters??
Anyway... I appreciate your confidence but be careful about other years & different cars.
Honda used 4 or more different fan control schemes over the years. So it's important to say what year car you're talking about. There's been 7 generations of Accord that are very different from each other.
Pretty much ALL of them have the primary fan switch in the thermostat housing (lower radiator hose) for when the car is running.
Certain years have the 2nd fan switch located in the head rather than in the upper radiator hose nozzle.
My '98 has NO 2nd switch, and the fan is NOT able to run after switching off the engine.
