Another gas mileage question.... 16 MPG
Originally Posted by Big AL
16 mpg would be generous if you live in an area like LA. You sit and sit in traffic and therefore your mileage is crap. The highways should be called parkways because parking is all you do once you get on one.:rant:
Originally Posted by sammy607
It's been 4 months since i bought my 98 Accord I4 5 speed that has 105k miles on it. I've replaced the following parts:
- timing belt and water pump
- spark plugs
- air filter
Originally Posted by Nors
Turn the key to the on position
ALL the lights on your dash should light up and turn off.
IF the CEL doesn't turn on at all there is no bulb.
I can't see someone getting 16 mpg and no check engine light.
Thanks for the info and quick reply...
The spark plugs i replaced with are NGK V-Power plugs. Indeed there's no check engine light on. I'm going to seafoam the engine, clean the EGR port, change PCV valve and see how i do on my next 2 fill ups.
Also, try some lucas fuel injector cleaner and test the resistance of the spark plug wires.
