Fst Idle Thermo Valve
Old 02-28-2006 | 01:04 AM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
sounds like the other mechanic was guessing... if the VSS is bad your speedo will operate intermitently, or not at all.
As for the intake gasket... I think you may be confusing it with the head gasket, if that goes bad THEN you'll find water in the oil, white smoke, etc. The intake gasket would be between the intake manifold and the engine block.
Sucks you wasted $100... but at least Honda straightened things out for ya.
Old 03-01-2006 | 09:52 AM
skylert's Avatar
skylert
Default Help?
I have a 92 Honda Accord LX SOHC with intermittent rough idling. Can someone show me with images or provide detail instructions on where to find and locate the IAVC and the FITV? I have noticed also that the car seems to run at a higher rpm rate while driving it. Does anyone have advice?
Thanks!
Old 03-01-2006 | 09:53 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Thanks!
Dude stop posting the same question and do a search. Several diagrams and even DIYs have been posted or links to them have been posted on this board.
Old 03-01-2006 | 10:00 AM
skylert's Avatar
skylert
Default Sorry
Sorry. Just trying to find some answers. I have looked around and havent had success finding the info. Can you help?
Old 03-01-2006 | 10:19 AM
98CoupeV6's Avatar
98CoupeV6
I can but I pretty much stopped Do a search for 'accord IACV' in this forum, or 'accord FITV', etc. It's a very very common issue.
Old 03-02-2006 | 07:49 AM
skylert's Avatar
skylert
Default FITV/IAVC Info
All,
After searching around for a few hours, I feel that it would be nice to have this information documented for others to utilize. I will provide links to a few sites that were extremely helpful in locating and identifying parts.
Honda Autoparts:
http://www.hondaautomotiveparts.com
Throttle Body Info and diagram:
http://www.hondaautomotiveparts.com/...=THROTTLE+BODY
FITV images and information:
http://www.honda-tech.com/zerothread?id=699787
Hope this helps.
