1993 Accord brake rotor replace tips.
Old 03-18-2006 | 09:46 PM
wedley2's Avatar
wedley2
bboy Wesley West
Originally Posted by Ahhcord EX96
you know man your so helpful! jsut today a friend of mine toldme the same thing I tried no to ask him cuz dont wanna boost his ego (laughs) but i came home and to check my email with a reply i had gotten from you in HondaAcura site man you said to do the same thing he did which is totally awsome!
So I'll go and try that out when I go to school only I'll thank you for it mostly and tell my instructer that I had done a research onhow to do it and some cool guy had helped me out. This way shows I worked on researching whichis a good thing. So thanks for the tips yo and Ill get back at cha when I get it the damn thing out!
PS you got an Accord what year? ya got pix? could you send tome on my email ? if you can. you can check my Accord out in this site Honda Show Off only mines a bit scarry lookin LOL Im not done with it.
http://hondashowoff.com/profile.php?id=4823
i have a 90...
Originally Posted by wed3k
sup guys, just finished my brake change with the hub over rotor design.
so...im sure everyone knows how to take the caliper, just one 14mm bolt for the hose and two 17mm bolts for the mounting.
take that bitch out.
1. blast off the axle nut
2. take cotter pin and castle nut off (17mm) and seperate the lower ball joint out with whatever method but i prefer this way...
i used a pry bar to fill the gap
3. push the axle through the spline? or hole or whatever
4. bust loose the 4-14mm bolts facing towards you but dont take them off, just loosen them like 180 degrees...(you might want to do this b4 taking the axle out otherwise it'll just spin. but if you have a impact gun, then go for it)
5. flip the whole assembly around and there will be 4 star shaped bolts, a 12pt 10mm socket will do. so bust those out.
6. get 4 10mmx1.25 and 60mm bolts long. costed me 6 dollars at orchard supply.
7. install and thread like halfway in and follow this video...
http://www.reaction-image.net/albums/w00t/rotor.wmv
well, if you are on 56k then it sucks for you but i shall explain it. once all of the bolts are in, just hammer the bolts in, and the whole assembly should pop out. remove the bolts
8. you should get something like this.
remove the 4-14mm bolts.
9. replace rotor and reassemble the assembly onto the car. the star shaped bolts should go on TIGHT, as tight as you can because it is supposed to be pressed on but fuck honda.
10. after that reverse assembly and light off a couple of these in celerbration of your new rotors :thumbsup:
http://www.reaction-image.net/albums...01010004_G.avi
http://www.reaction-image.net/albums/w00t/pete.avi
http://www.reaction-image.net/albums/w00t/firework.avi
Old 03-18-2006 | 10:03 PM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
It's easy if you know what you're doing. I use old head bolts to thread in the hub and then I pound it out with a BFH. On the car lathes are better if the rotor has enough material left to refinish it. It's better because the lathe is mounted to the vehicle and any inperfections in the wheel bearings/hubs will be there when the rotors are refinished so you won't notice any vibration later.
Old 03-18-2006 | 10:36 PM
Ahhcord EX96's Avatar
Ahhcord EX96
Ahh I see hummthis seems to be the way to get it off huh? if its a doit yourself kinda way I doubt shops do this unless its not a big name shops like the Honda dealer or something lol. well thanks man I apreciate your time to let me know how you did it. I will try it asap when I can.
JOe
Old 03-19-2006 | 11:22 AM
hondatech's Avatar
hondatech
I'm at the dealership and we all do it this way, if you're not a hack you shouldn't hurt anything.
