Help:Complexity of Changing Rotors in '94 Accord
Old 10-14-2005 | 08:33 AM
Tom T's Avatar
Tom T
Default Help:Complexity of Changing Rotors in '94 Accord
I heard 1/2 the front-end has to come out in order to change the rotors
on a '94 Accord. Sounds like a ridiculous enginerring feat by Honda. What year did they change this? (e.g. did it run the entire cycle through this body-style until 1997)?
also, approx. how much addit. labor hours will we be hit with to change the rotors/pads as a result??? My daughter's car is vibrating when braking & we know it needs new rotors up front.... thanks
Old 10-14-2005 | 10:38 AM
shonnv's Avatar
shonnv
7th Gen Coupe V6
What do you mean by 1/2 front end of the car. I never heard of anything like this. It probably your mechanic trying to rip you off so go to another one.
Changing the rotors and pads is never more than 2 hours of labor as far as I know regardless of vehicle's age,make and model.
Edit: Usually it is under 1 hour
Old 10-14-2005 | 10:40 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
isn't their a 50 post thread on this within the last week?
Old 10-14-2005 | 10:43 AM
shonnv's Avatar
shonnv
7th Gen Coupe V6
Yeah you are right, Good memory
https://www.honda-acura.net/forums/s...d.php?t=207293
Old 10-14-2005 | 11:16 AM
jschmid's Avatar
jschmid
Unfortunately yes, it's a horrible design...most call it a "hub-over-rotor" design, that requires you to remove the hub just to get to the rotors, really stupid. Luckily they did change that in 98 going with the rotor-over hub design...takes about an hour to change pads and rotors instead of the half day DIY project on the older Accords.
But there are some DIY threads here on the board, search and you'll find some.
Read above...your rotors won't take more than an hour, but people with the older Accords have said the job has taken upwards of 6 hours to DIY.
Old 10-14-2005 | 11:21 AM
shonnv's Avatar
shonnv
7th Gen Coupe V6
He is talking about getting it done from a mechanic i think since he mentioned labour hours. DIY mostly takes long for us since we dont have a lot of practice and knowledge.
Old 10-14-2005 | 11:57 AM
strykernyc's Avatar
strykernyc
every shop i gone they all said the same thing. 2hrs job min and they will charge up to $200 to change both front, just labor. the dealer will give u stocck rotors plus labor=$400 and up.
Old 10-14-2005 | 12:45 PM
shonnv's Avatar
shonnv
7th Gen Coupe V6
Dang! that sucks
Old 10-15-2005 | 12:49 PM
Tom T's Avatar
Tom T
Default thanx for responses... all (doesn't sound like fun)
"Hub over Rotor design " were the engineers at Honda back then upset about something and wanted to piss off everyone who wanted to change their own brakes??? urgh!!!
thanks all...... Tom
Old 10-19-2005 | 11:42 AM
Tom T's Avatar
Tom T
Default Have update: 3.5 hours of labor...ouch
and he claims the book calls for 4 hous for this job...ouch
